Sensitive brakes
Old Jul 27, 2011 | 07:15 AM
ricklovin93's Avatar
Car: 1988 camaro base coupe
Engine: 305 LO3
Transmission: gm 700-r4
Sensitive brakes
I drive an 88 camaro sport coupe with LO3 v8. My brakes seem extremely sensitive at times. sometimes they give me such problems that the right front will lock up at times when im just trying to stop at a stop sign. Do i just need new pad and rotors? And if so whats a good performance replacement? Or is there a bigger problem?
Old Jul 27, 2011 | 06:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Sensitive brakes
Sounds like you have a driver front caliper issue - maybe the piston is froze and not working properly. I'd tear the caliper off (don't remove the rubber line just yet), and see if you can move the piston inwards (with a large C-clamp).
Old Jul 27, 2011 | 09:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The flex line itself might well be the culprit.
JamesC
Old Aug 12, 2011 | 03:45 PM
Guest
Guest
Posts: n/a
This '86 Camaro I just bought is doing about the same thing. Both fronts will lock the tires if I want, but for normal braking, it seems the right front grabs sooner and better than the left front.
I checked the tire pressures, I replaced the rotten-looking RF rubber brake hose, I bled both front brakes, no improvement.
It's a little bit worrisome, and I definitely need it resolved before winter, even if I can get it inspected and registered this way. My temp tag expires soon, too.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
