9" with LT1/PBR rear brakes
Ok so I want to install lower control arm relo brackets but my ebrake bracket is in the way. Has anyone else encountered this? Would switching to LS1 rear brakes help?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 9" with LT1/PBR rear brakes
the ls1 e-brake brackets also require modification to work with LCARB's. Just a simple cut, reweld if you want but no required.
Eric-86sc
Apr 3, 2016 03:52 PM
