9 bolt 13 inch rear brackets
Old Aug 3, 2011 | 03:34 AM
Twin_Turbo's Avatar
Does anyone have a drawing for these brackets? 12 will do too, can easily modify the design. Takes too long to order fron Ed. Also, does this use a c5 rotor?? Talking about convetsion using stock pbr calipers. A drawing for the 12/13 front brackets woyld be handy too but I have a set I can measure/duplicate if not.
Old Aug 4, 2011 | 03:26 AM
Twin_Turbo's Avatar
Re: 9 bolt 13 inch rear brackets
No one?
Old Aug 4, 2011 | 07:53 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
When I put my 13 rear Baer rotors on they sent a adapter that bolts 2 the orginal rear 9bolt disk brake bracket and spaces the org PBR caliper out the proper distance. they are now on my 9" rear. Im still iffy about the extra parts but its nice 4 me because the 13" rotor caliper wont fit inside my 15" drag lites and it makes it easy 2 swap back to stock rotor size. Baer sells the proper "thin" 13" rotor and adapter bracket 4 these cars. Duno if that helps ya or not.
Edit.. I went out and took a pic of my Baer bracket. I thought it used the stock bracket, I'm old and def wrong, its all from Baer. I have to pull my axles to put the stock 9bolt brake bracket back on. Baer did thers with a big slot to slide over the axle..
Old Aug 4, 2011 | 08:00 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I don't know if he has anything for a 9-bolt, but you could ask maybe?
http://www.lukeskaff.com/car/brakes/bracket.html
Old Aug 4, 2011 | 04:21 PM
TTOP350's Avatar
put a pic in above post
Old Aug 5, 2011 | 06:09 AM
Twin_Turbo's Avatar
Lukestaff doesn't have anything for 9 bolts and I'd like 1 bracket not an adapter bracket for the oem one. I have a set from Miller on my camaro but don't feel like pulling the axle out to measure the bracket.
Old Aug 23, 2011 | 02:12 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Id been interested as well...
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
