proportioning valve mod/ which 1 is truly correct?
Old Aug 3, 2011 | 05:00 PM
jpoeling's Avatar
I have an 88 formula with a 4th gen disc brake conversion on the rear. My question is which mod to the proportioning valve is actually correct. I have read many many many posts on here and by just googling to figure this out and it seems to be a 50/50 so far depending on where you look.
1st mod is the removal of the spring and plunger all together. This is how my car was when i originally bought it from previous owner.
2nd mod is to install a stiffer spring into the pv. I have currently done this because i didnt feel the rear breaks where working as well as they should or maybe even at all.
I will be purchasing a wilwood pv this week anyhow regardless of which of these 2 is correct but now I have to find out which is correct otherwise it will drive me nutty.
Also lets not turn this into what many other posts have been where people state that it is a suspension issue or chassis or any other type of fault of the car why the brakes may or may not work.. I just want a true answer from someone that actually knows 100% the correct way these pv's work and which mod is correct.
Old Aug 4, 2011 | 03:17 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: proportioning valve mod/ which 1 is truly correct?
you'll want to change the spring if you swapping from drum to disk, not remove it. the spring rate is what changes the rear bias. without any spring in place, you're rears will not be doing anything.
Old Sep 21, 2011 | 11:28 PM
BobbyRod's Avatar
Car: CAMARO RS 25th Anniversary Z03
Engine: L03 V8 5.0
Transmission: THM 700 R4
Axle/Gears: 2.73 OPEN
ok Dan, so where can i find this spring, PN maybe? thank you!
Old May 7, 2012 | 11:32 AM
BobbyRod's Avatar
Engine: L03 V8 5.0
Hey DAN!!! Any info about this spring?? P/N, brand? any help would be appreciated, Thank you!!
Old May 7, 2012 | 03:23 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
dunno how I missed this one, oops!
I got all my info from here:
https://www.thirdgen.org/forums/brak...e-upgrade.html
Old May 7, 2012 | 10:25 PM
BobbyRod's Avatar
Engine: L03 V8 5.0
Thanks DAN!!! lotta time searchin' for this info
gta90
Sep 15, 2015 04:00 PM
mike_c
Aug 27, 2015 04:32 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
lakeffect2
Aug 23, 2015 08:44 AM
g.l.mos
Aug 22, 2015 12:02 AM
