ls1 & 1LE brake swap quesions
Old May 2, 2012 | 10:59 AM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
My car came with drums 2.73 rear end now has a 3.27 9 bolt disk. I have all the calipers just need the brackets. My question is will a proportioning valve from a 4 disk 3gen work. What would happen if I do. The 1LE PV would be best or do I need a aft mrk 1 thanks
Old May 2, 2012 | 12:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: ls1 & 1LE brake swap quesions
Yes, the standard J65 combination valve will work (for that matter a J50 will work), but it's not designed for the 1LE rears. Personally, I'd swap in the correct 1LE valve, which would be less hassle than an adjustable after market.
JamesC
Old May 2, 2012 | 11:59 PM
Sojer's Avatar
JamesC
The 1le is not made for ls1 fronts, so it would still be lacking. I think I will go with stock 4 disk PV and upgrade l8r to 1le. I don't need that much stoping power in a car with no abs. The wheels would lock up and that's no good. And 1le rears I was talking about lt1 rears I know they the same but just to let u know
Old May 3, 2012 | 06:16 AM
JamesC's Avatar
A combination valve proportions to the rears. Good luck with your project.
JamesC
Old May 7, 2012 | 11:26 PM
Sojer's Avatar
I thoght it did for the front and rears I got u. So it just put out max the front and what ever the PV rear is made for. Smart man thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
