different mounting locations for brakes on 1983 Trans Am
Car: 1983 Trans Am
Transmission: thm350
I was in the midst of doing a brake bleeding after I replaced a bad master cylinder and snapped a bleeder screw. I also noticed that my pass. rear caliper was mounted on front part of rotor. Where as my drivers rear was mounted on the back part of the rotor. I have since found out it was a normal thing on that year. My question is is there anything I can do to set it up so they are both on the back or vice versa both on the front.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: different mounting locations for brakes on 1983 Trans Am
Not with those calipers
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
All years through 88. In 89, both calipers went to the backside. That swap is common:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
JamesC
Terrell351
Jun 13, 2021 01:13 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
