axle swap problem with e brake cable
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
i just swapped in a disc rear out of a 92 z28 25th and the brake cables are long enough to attach to the 2 into one connector but the clips the are on the sides before dont line up they are too farr towards the axle to reach the holes. should i pull the ebrake to pull them forward to meet the holes and put the clips in or do i need different cables?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: axle swap problem with e brake cable
That said, the 1st design cable, used with a tunnel adjuster, is 1434 mm. The second design is 1460 mm. This longer cable was designed for cars with no adjustment provision.
JamesC
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
its just the e brake cables clips dont line up with the tunnel mount. but im thinkin if i pull the e brake to pull them closer and clip them on then release it. ill be alright. not sure. jus wondeing if anyone has ran into the same problem
Eric-86sc
Apr 3, 2016 03:52 PM
red90IROCls1
Aug 25, 2015 06:56 AM
db057
Aug 11, 2015 10:11 PM
