Lets talk prop valves
Old Aug 15, 2011 | 09:02 PM
Pocket's Avatar
Car: 91 Trans Am
I was under the impression the whole prop valve had to change for a disk conversion. I happen to have both disk and drum to examine so i opened them up to see
The body itself appears to be identical, only the valve itself changed. Comparing the springs, they seem the same stiffness even though they are visually different. Only diff I can spot is the spring seat location on the valve itself. Seems any drum prop valve can be converted to disk simply by swapping to a stiffer spring
Any thoughts?
Old Aug 15, 2011 | 09:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Lets talk prop valves
is that the front or rear circuit? doesnt the rear have a spring too?
Old Aug 16, 2011 | 10:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
A disc/drum combo valve should also have a metering valve for the front lines. This is to hold off the fronts until some pressure is built in the rear lines. This is to spread the braking effort between the fronts & rears.
Pull the front sections of the valves apart. There should be a difference between them.
I checked the '92 FSM and there isn't any diagrams of the combo valves.
RBob.
Old May 16, 2012 | 06:07 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Never mind
Hotrodboba400
Dec 10, 2019 07:07 PM
355tpipickup
Sep 13, 2015 11:35 PM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
