'88 rear disc defect-cheap easy fix, upgrade?
Old Sep 2, 2011 | 07:19 PM
turbosbox's Avatar
Car: 88 TPI formula
Engine: L98 Vortech
Transmission: TH700r4
IIRC the discs in the rear were subject to a recall due to sticking and not working. I confirmed mine are not working.
I think I saw a NOS fix kit but is that the cheapest best action? Due to the fact it's the rear's and not front's I don't really want to dump big $$$ into upgrade there. Yes, I'll do more search and reading, but if you feel like commenting on a simple fix and upgrade is even better. Most threads are about expensive upgrades to not quite as easy to find the cheap upgrade answer I was looking for.
E.g. 89-up is a bolt on to the 9bolt? cheap at the pick and pulls?
4th gens will bolt on?
thanks for any ideas
Found a few threads so far: https://www.thirdgen.org/forums/faq-...iscs-89-a.html
https://www.thirdgen.org/forums/brak...ns-88-9-a.html
https://www.thirdgen.org/forums/brak...-sticking.html
http://www.lukeskaff.com/car/brakes/...e_options.html
The 89-up PBR might be the best solution(?)
Old Sep 2, 2011 | 08:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: '88 rear disc defect-cheap easy fix, upgrade?
EDIT: Sorry I just noticed the title of the thread. With the correct 9-bolt backing plates, you can equip your 88 with PBR's. The calipers are virtually the same, 89-97.
That said, though the old-style Delco-Moraine calipers have a bad reputation on TGO, I thought they worked fine. New rotors, pads, braided steel lines all around, perhaps new calipers, and a fluid change and you might be well surprised/satisfied--and at a price you can live with.
JamesC
Old Sep 2, 2011 | 09:58 PM
turbosbox's Avatar
Car: 88 TPI formula
Engine: L98 Vortech
JamesC
Sounds logical. I'm going to pull them and see if I can rebuild them and add new rotors pads and lines as you suggest. I'm not looking for too much from the rears, and don't think I can do much better at low $. Maybe I'll do the same for the fronts
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Dkelz313
Apr 7, 2016 10:38 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
