Found a gremlin today
Old Sep 27, 2011 | 01:52 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Did the first brake job today on the rear brakes since I've owned the car (3.5 years) and discovered the brake shoes were barely worn. The oddest thing I discovered however was that the parking brake lever was installed onto the brake line backwards, resulting in the lever not resting in the actuator rod.
Just curious what kind of strange effects this has been having over all this time. I did notice after the car felt like it stopped a bit easier.
Old Oct 2, 2011 | 10:24 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Found a gremlin today
If memory serves correctly (& thats a BIG if...), for drum brakes,
activating the parking brake also serves to inject some star wheel
adjustment. So if the p-b was backwards, this may have been a
significant effect.
I personally don't trust this, and periodically just adjust the
rear brakes up a bit. A good gauge seems to be when the p-b
needs lots of lever travel to engage.
I would be interested in how others experience/handle rear
brake adjustment.
Old Oct 3, 2011 | 09:03 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
brake adjustment.
While driving in reverse aggressively pump the brake pedal while coming to a stop. This is to be done with the brakes cold.
Doing it with hot drums will cause them to over adjust and then drag while cold.
RBob.
bjpotter
Jan 22, 2019 12:27 PM
1Aauto
Sponsored Vendors
Aug 31, 2015 09:46 AM
spaigo
Aug 21, 2015 07:46 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
