HELP.. compressing pistons on rear calipers
Car: 87 Iroc
Engine: built 355, 450HP
Transmission: built 700r4
Hi, Im new to this board and this is my first post. I just bought an 87 Iroc this week and am in the process of getting it ready for a safety check. Im putting new rear pads on and I cannot get the pistons in the rear calipers to compress so I can fit the new pads in. What am I doing wrong.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: HELP.. compressing pistons on rear calipers
they need to be screwed/rotated back in. You need a tool for this thats available at most any auto parts store. Its a small cube with square holes and tabs all over it.
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Specialty tools are usually more efficient, but other things may be
more cost effective. With some time/patience, and a big enough
C-clamp, I've always managed to get the caliper pistons recessed.
A big vice and some spacers/wood blocks/??? could also prove
successful.
The key is:
yes, the caliper pistons need to be recessed back
yes, it will take a modest amount of continuous force
no, do not be tempted to use any size hammer
Or
"Along will come a fool, bigger than the proof"
successful.
The key is:
"i thought the plan was fool proof?"
"fool proof, yes. idiot proof, no."
Car: 87 Iroc
Thanks guys...I got er done. I just had to re-read my manual and noticed I miss a step.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
successful.
successful.
Car: check
Engine: check
Transmission: check
Note for other readers, this is referring to the rear calipers.
RBob.
ambainb
Apr 25, 2016 09:21 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
