need help!!
Old Oct 2, 2011 | 08:56 PM
dvdlovesbball's Avatar
Car: 1987 iroc-z
Engine: 5.0 305 carb
Axle/Gears: stock 10 bolt
need help!!
i need some help picking what front brake kit to put on my 87 iroc. i want to use my stock rims and am looking to spend less than $500 but would consider up to $900. i want something that is a bolt on kit without alot of modification, that will sicnificantly increase the performance of my brakes. heres what im looking at...
http://www.summitracing.com/parts/SSB-A181/
http://www.wilwood.com/BrakeKits/Bra...&modoption=All
Old Oct 3, 2011 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: need help!!
You might do a search on the SSB stuff as some members don't think very highly of them (and I doubt there'd be a significant increase in performance). The Wilwood link doesn't work for me.
You may find info below interesting:
https://www.thirdgen.org/forums/brak...-srtaight.html
There really isn't a lot of modification to be concerned about if you went, say, 1LE, and they would be at the upper end of your budget, IIRC.
http://web.archive.org/web/200605221.../1LEbrake.html
http://www.flynbye.com/catalog/i55.html
JamesC
Old Oct 28, 2011 | 03:36 AM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: need help!!
If you want more stopping power check out this link.
http://www.hydratechbraking.com/
