Parking Brake Not working right: 86 Z28, rear disc
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Hello,
I have an 86 Z28 with rear discs, and the parking brake grabs a little when applied, but not quite enough to "hold" the car from moving when in gear (automatic). This will not pass safety inspection.
I have the adjuster/equalizer noted in the attached pic. This is not a pic of my actual car, but I have the same one...HOWEVER it appears to be bent a bit, and there is more slack on one of the cables than the other.
Couple of questions for you guys:
- When tightening the adjuster/equalizer to pick up slack, it appears that the 1/2" nut should be turned clockwise while holding the 5/16" threaded rod. Am I correct?
- Has anyone ever used a Dorman parking brake cable tensioner to pick up loose slack? If so, then please do post pics if you can.
- This thing is a PAIN IN THE NECK to adjust when the drivshaft is in the car. Any tips/tricks?
- Lubrication: What is the best way to lubricate the ratcheting mechanism? Do I need to go in through the interior (console)?
- Should I lubricate anything on the brake caliper assemblies themselves? Any adjustments on teh brake caliper assemblies?
Please share any relevant tips or points. Many thanks guys.
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Parking Brake Not working right: 86 Z28, rear disc
1. regular thread; "left loose, right tight"
2. no input, haven't tried
3. i love my ratcheting wrenches, makes this job a bit less miserable
4. i would hit the threads up with some pb blaster and a soft wire brush to get rid of any light rust and grime, followed by a little bit of white lithium. by nature, it should fight you due to the lock nut on there (don't want this getting loose) but it should help a bit.
5. not sure here, so i'll leave it to others to answer
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://members.shaw.ca/crussel/recalls/86c28/86c28.html
JamesC
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Hello,
Based on what your describing it sounds like your calipers need to be adjusted. Since the cable on one side is stretched it would be a good idea to replace both cables. As long as the adjuster doesn't bind with anything and it operates as designed a minor bend in the adjuster isn't a big deal.
Check out this thread for info to adjust your rear calipers. I used the deepest socket I could find with a 12" extension. I used a 4" pair of vice grips to hold the rod while adjusting the tensioner nut. With the ratchet and extension I can angle it down to make adjusting the nut easier.
https://www.thirdgen.org/forums/brak...rear-disc.html
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
