86 TA WS6 to base 91 parts swap?
Old Oct 31, 2011 | 12:33 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I picked up a '86 Trans Am (WS6) roller for $300 to scavenge parts from for my '91 base model 3.1. I need the windshield and it's got a BW disc posi and bigger front discs I think (anyone know the options?) plus some other bits and pieces. A good I think. My main question is what issues am I likely to run into when swapping over the front brakes? I've read about different brake line threads. ? Should I also swap spindles? Any other swap suggestions?
I'll also be parting out the rest. T tops, tan interior, heated hatch, hood, full power doors (windows, locks mirrors) console etc.
Old Nov 3, 2011 | 09:08 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 86 TA WS6 to base 91 parts swap?
front brakes should be the same unless you've got the aluminum dual piston calipers, but i doubt it if they were never upgraded.
not too much to really grab as upgrades under car wise. may have bigger sway bars and better springs, but the springs are probably a bit worn out by this point. grabbing the rear is not a bad idea. if you do the swap, make sure to grab the proportioning valve as well
Old Nov 3, 2011 | 09:16 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've read about different brake line threads?
Unless someone has swapped in the 1LE set-up, the car will have standard disc brakes (10.5" rotors and iron Delco-Moraine calipers).
The combination valve threads in the 86 won't fit your 91.
There are two spindles: Standard and 1LE (and even the latter is a standard spindle with the ears cut off to accommodate larger brakes.
JamesC
Old Nov 4, 2011 | 06:56 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
oops, sorry about that; forgot they changed the fittings
1992 Trans Am
May 10, 2023 07:19 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
