drum rear potential?
Old Nov 2, 2011 | 08:03 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
I know the best way to make drum brakes better is to get discs, but is there anything you can do to the drums to make them better? Stronger drum?
Old Nov 2, 2011 | 08:48 PM
T/A's Avatar
T/A
Car: 1990 T/A w/WS6
Engine: 5.7L V8 TPI
Axle/Gears: 3.23 w/ posi
Re: drum rear potential?
not that i know of, but i'd ask someone with a 2nd gen as some of them have rear drums (my fathers included). However i'd put discs on because its more efficient, plus I always laugh at those stickers they had on older T/As that said
'4 wheel disc' LOL
I Read up a little, apparently high quality shoes might help, but who knows.
Old Nov 2, 2011 | 08:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I know the best way to make drum brakes better is to get discs....
Though I personally never experienced issues with the 82-88 Delco-Moraines, many members have--some even venturing the opinion that drums are superior to the above discs.
JamesC
Old Nov 6, 2011 | 02:35 AM
profootbrake2's Avatar
Car: 92 Camaro Z28
Engine: ZZ4 TPI
One of the best things to do is make sure everything is working and adjusted correctly.
Old Dec 1, 2011 | 01:29 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
A properly setup rear drum system should have NO problem stopping the car. Problem is, most aren't adjusted properly or the brake fluid is contaminated from still being factory fluid. On a third generation F body, thats scary.
Old Dec 1, 2011 | 02:45 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
A larger drum would give you more surface/contact area, which should increase stopping power. Maybe different brake shoe material would also help a little....but in the end, discs will almost always provide better stopping power.
There's inherant issues with all drum bakes, mostly overheating/fading and the like. That being said, I run larger Ford Explorer drums on the rear of my car (I have to with the Moser 9") - and they do much better than the stock drums that came with the car. So much so that I'm really not looking to upgrade them to disk brakes in the near future.
Old Dec 1, 2011 | 04:28 PM
Car: White 84 z28
Engine: Chevy 350
My car stops fine in an everyday sense, but im thinking more for performance. Late brake into corners
Orr89RocZ
Apr 25, 2016 08:28 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
3rdgenparts
Aug 6, 2015 09:03 AM
