Help on figuring if i have 1le ???
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
How can i know if i have 1le package its a 91 z28 with all wheel discs thanks
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Re: Help on figuring if i have 1le ???
Check your RPO codes inside the center console to see if "1LE" is among them.
Look at your front brakes. Ignoring the drilled/slotted rotor, do your calipers look like the ones on the left (standard) or the right? (1LE)
Engine: 350ci TPI
I checked on the center console and didnt see no 1le just saw z28 and l98 that looked reasonable to understand and im guessing idnt have it cuz i have standard calipers lol well just wanted to know before i buy some drilled slotted rotors thanks alot!!!
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Periods, my good friend, periods.
Punctuation and capitalization are the difference between "I helped my uncle, Jack, off his horse", and..... something else.
Make your posts legible and people will be more inclined to help.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
