c5 front brakes dragging
Old Jan 17, 2012 | 10:15 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
I am a bit stumped with this problem. I am doing a hsr swap and noticed by accident that I could not turn my front wheels without a lot of effort. I bled out the lines, no change. If I take a hammer and lightly pound on the calipers, they will release some, but still drag some. I replaced the hoses, then exchanged the calipers and brackets, still the same effect. Is it possible the prop valve is holding a little pressure in the lines or the master is bad? I also followed the line and there are no kinks in them anywhere. The ls1 rears seem to be just fine. I am really confused to what is going on.
Old Jan 17, 2012 | 10:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: c5 front brakes dragging
Some drag is normal.
JamesC
Old Jan 17, 2012 | 10:57 AM
dellman83Z's Avatar
The only way to get them to drag a little is to pound on them some, especially the RH side. It takes quite a bit of effort to turn the wheel. It's acts like the pedal is depressed some, when its not, at least I don't think it is.
Old Jan 17, 2012 | 04:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
take them apart and grease the caliper pins. they do need grease and they may be siezing
Old Jan 17, 2012 | 05:10 PM
dellman83Z's Avatar
They are new and greased. Before I put them on again, I made sure they moved like butter.
Old Jan 20, 2012 | 01:37 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have a friend that has the same calipers with the same problem. The calipers (GM) and lines are all new.
With the car jacked up the tire will barely make 2 spins. We pulled the caliper off and the rotor spins freely.
My car with the Baer setup will free spin the front tires for almost 2mins. My Pads are completely released his arn't at all.
Old Jan 25, 2012 | 08:25 AM
dellman83Z's Avatar
two spins I would say is an ok amount of drag. Mine on the other hand is about a half turn at best.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
