Real 1le spindles or modified standard spindles?
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I found a guy selling 1le spindles and I want to make sure they are the real thing. They have casting flash and the surfaces do not look like they have been cut. The finish has that wrinkle-rough look. Any advice? How much are they worth? Thx.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Real 1le spindles or modified standard spindles?
IIRC, from what anyone has been able to tell, real 1LE spindles are cut-down standard spindles.
Car: 91 Formula
That makes sense but the surfaces where you cut to modify them is not smooth. A modified cast form might have been cheaper than paying a worker and wasted material.
Car: 91 Formula
the spindle has concaved dimples also. I don't think standard spindles had them. Joined: Aug 1999
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, chazman, actually purchased new 1LE spindles some time ago. Perhaps a PM to him would answer your questions.
JamesC
JamesC
Engine: 4++,350 & 305 CIs
I have 1LE spindles and to me it "looks" like GM modified a stock spindle to make a mold for the 1LE spindle.
It has a cast look to the areas that would normally have the cut look of a normal spindle..
Car: 91 Formula
I believe that the cast look and the concave dimples are OE. I wonder if GM ran out of them later and decided to modify the standard spindle to meet demand.
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
