Another brake question
Old Feb 6, 2012 | 05:35 PM
F15david's Avatar
Car: 91 RS
Engine: 383 Stoker
Transmission: Monster Mortorsports built 700R4
Axle/Gears: 9 bolt 3.27
I just picked up a 9 bolt rear for my 91 rs. It has rear disk opposed to the factory drum brakes. First off will my proportioning valve need to be changed or did the disks and drums used the same valve. Second, I am not sure what year the 9 bolt came off of; do all third gen rear disk use the same pads or do they vary by year? Thanks Guys
Old Feb 6, 2012 | 06:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Another brake question
pads depend on what brakes are on it. if they are iron caliper, they suck, aluminum calipers are the best ones. they both use different pads, and the change was in 88 or 89 IIRC.
your prop valve will "work" but a proper disc/disc valve will be better.
Old Feb 6, 2012 | 08:10 PM
F15david's Avatar
Car: 91 RS
Engine: 383 Stoker
I have Iron calipers on the back. So i would be safe with any pre 88 rear brake pads? Just want make sure I order the right stuff.
Old Feb 6, 2012 | 08:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
yeah, they are the same
Old Feb 6, 2012 | 09:16 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
What makes the iron ones suck?
Old Feb 6, 2012 | 09:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
they are notorious for not working, at all. search, there are many threads trying to "fix" the problems.
Old Feb 7, 2012 | 07:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The old Delco-Moraine calipers (82-88) certainly have a bad reputation on TGO, though from my own experience, I'm uncertain that it's entirely merited. With new calipers (or old ones with the "fix" kit in place) and frequent use of the parking brake, I personally had no issues.
As 86 mentions, the new style system with PBR's (89-92) is the better choice. These can be swapped to your 9-bolt.
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
You may also find info in the following to be of interest where combination valves, master cylinders, and parking brake cables are concerned:
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
