Rotor caliper issue. Help....
Old Feb 9, 2012 | 09:24 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
The back side of my rotor is hitting the caliper case and rubbing metal to metal on my 4th gen conversion. I am wondering how to correct the problem, would I make a 1/8 spacer to put between the axel and the rotor? Any help would be much appreciated.
Old Feb 10, 2012 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rotor caliper issue. Help....
Did you use LT1 backing plates? Some 90-92 10-bolts with PBR's (which are the same as the 93-97 version) required shims to center the calipers over the rotor. Shims can be seen below in post #2 (behind the backing plate and on the floor):
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Any pics of your set-up?
JamesC
Old Feb 24, 2012 | 07:13 AM
Ryan 97 WS6 T/A's Avatar
It's your axles. If you put 93-97 brakes on a 98+ rear the axles aren't the correct length. You need to get a set off an LT1.
Wish I had caught you sooner, I have a complete 3 channel swap off a 2001. Just joined this board specifically to sell it.
Old Feb 24, 2012 | 07:28 AM
JamesC's Avatar
Hey, Ryan,
Welcome to TGO.
It would have been nice for the OP to have checked back in so that he could have detailed exactly what his 'fourthgen' conversion was.
JamesC
Old Feb 24, 2012 | 08:08 AM
Thanks James. What's OP mean?
PM'd you
Old Feb 24, 2012 | 08:16 AM
JamesC's Avatar
Originally Posted by Ryan 97 WS6 T/A
What's OP mean?
PM'd you
Original Poster.
Saw the PM. Will do.
JamesC
Fanatic1074
Oct 3, 2022 05:57 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
Lmancha96
Sep 25, 2015 08:11 PM
