LT1 Rotors fit on 92 Camaro
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Will LT1 rotors fit on a 92 Camaro with modifying anything? I have the stock brake setup up front now, but was curious to know if the LT1's would fit right in. Have gotten some vague answers from searching thus far. I now have a 4th gen rear and can get a good deal on brand new set of 4 LT1 rotors but want to make sure they will fit up front first.
thanks
thanks
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Re: LT1 Rotors fit on 92 Camaro
nevermind, just found out its an LS1 rear end..
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The LT rear brakes are really no different that 89-92 rear discs, just on a wider axle. You can grab the whole rearend for better brakes if you have drums & for the front: http://bigbrakeupgrade.com/index.html
