New brake line install
Old Feb 23, 2012 | 02:47 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so I'm replacing all the brake lineS an hoses on my 88 Gta from the proportional valve all the way to the back an to each caliper does it really matter if the new brake lines dOnt have the stupid circle bends like the original one did right under the proportional valve ????
Old Feb 23, 2012 | 02:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: New brake line install
No.
JamesC
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Put the loops in, they're for strain relief.
Old Feb 23, 2012 | 03:04 PM
JamesC's Avatar
I see. So there is enough length to bend the lines appropriately?
JamesC
Old Feb 27, 2012 | 03:46 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
You don't necessarily need the loops, but as mentioned before they are for strain relief as the body flexes. However they also can make installation easier by giving you some leeway for fitting. If you put an extra loop at the end, it will allow you to make the line longer or shorter by expanding or shrinking the loop so you can get the nut to end up in the right place.
Old Feb 27, 2012 | 07:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
open the hood, and press the brake pedal really hard. See how much the master movers up and down? its noticeable. Those loops help to keep that stress from the lines and eventually causing them to fail. Granted that may take decades, but its still possible
Old Feb 27, 2012 | 09:00 PM
JamesC's Avatar
I wonder how often the hoops are eliminated when an adjustable proportioning valve is installed? And is a slight bend or two sufficient for strain relief?
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
