Prop Valve Cheat Sheet?
Old Mar 2, 2012 | 08:49 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Can someone point me to someplace that tells me what goes where on my 1LE prop valve. It seems quite different than the '83 I got rid of. Now that it is time to hook back up, I'm doing some head scratching.
Old Mar 2, 2012 | 09:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Prop Valve Cheat Sheet?
Your 83 cast-iron combination valve may well have SAE threads; the alum 1LE valve will be metric. Double check that fitment. Here's a recent post that may be helpful where the lines are concerned:
https://www.thirdgen.org/forums/brak...rear-swap.html
JamesC
Old Mar 2, 2012 | 10:09 AM
Flip 2's Avatar
Engine: C5 LS1
Hi James-
Yes, I got that all my old threads won't fit.
I want to find out what should go where on the new Prob Valve. Then build out from there. I have already junked the old lines, except the front to back that goes to the rear axle. I will probably have to junk that, too.
Phil
Old Mar 2, 2012 | 10:42 AM
JamesC's Avatar
Front bottom is the rear line.
Rear bottom is the pass side front.
Top rear is driver's side front.
JamesC
Old Mar 2, 2012 | 06:09 PM
Flip 2's Avatar
Engine: C5 LS1
That's it, thanks.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
