Spindles
Old Mar 9, 2012 | 02:18 PM
Jaboski's Avatar
Car: 91 Firebird
Axle/Gears: 3.08
Spindles
Are base firebird spindles the same as a t/a or car with thR 1le package? I would assume upgrading the brakes wouldn't be as easy as changing rotors/calipers/hoses/pads to the better package?
Old Mar 9, 2012 | 02:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Spindles
Spindles are all the same with the exception of the 1LE spindles, which are OE spindles with the ears cut off. You're correct. Bigger brakes require a spindle modification. Some links below offer insight:
http://web.archive.org/web/200605221.../1LEbrake.html
http://lukeskaff.com/?page_id=396
JamesC
Old Mar 11, 2012 | 08:51 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Re: Spindles
Member Ed saying once there was a slight difference. 89 up having a thicker casting somewhere. Don't remeber where but that made me decide to use mine.
Old Mar 11, 2012 | 08:57 PM
JamesC's Avatar
Re: Spindles
Some discussion about differences in the following link. AndyZ28 noted that the difference was around the bosses but that the difference wasn't worth the attempt to locate 89+ spindles (when upgrading to 1LE's).
https://www.thirdgen.org/forums/brak...questions.html
JamesC
Old Mar 11, 2012 | 08:59 PM
Jetmeck's Avatar
Re: Spindles
Sounds like what I read but hey if you already got an 89 might as well go with them.................
Ghettobird52
Apr 21, 2020 08:44 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
jdperformance
Sep 16, 2015 11:55 AM
rb85TA
26
Sep 14, 2015 10:29 PM
