I did a swap
Old Apr 30, 2012 | 11:02 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
I did a swap
...about 5 years ago. I have an 88 IROC and while swapping motor and trans I swapped the rear end (went from drum to disc). I put in a complete rear out of a 96SS. The brakes have always worked, just not terrific. I did not swap prop valves, masters or anything else. The past year the pedal is edging closer and closer to the floor, but stopping fine. I don't like it. Pads and rotors are well within spec. No leaky lines. Where should I begin? thanks
Old Apr 30, 2012 | 11:42 PM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
Re: I did a swap
bleeddd the brakes its the cheapest place to start
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
