braided line question
im looking to buy a kit for my 92. Now the wuestion is....i plan on doing a c5 front brake upgrade.....do I need the hoses specific for those calipers or do the stock ones bolt up?
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Re: braided line question
the stock lines will fit for the front and back? I have most of the components for the LS1 brake swap except the braided lines. Should i order LS1 lines or lines for a 92?
thanks
thanks
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
they will be fine for the front, if you are also using ls1 rear brakes, you should get the proper lines for that year. They will still have the same flares, but are the proper length to work with the ls1 style brake hose retaining bracket that bolts to the axle.
3rd gen front hoses, 98-02 4th gen rear hoses. The hose from the chassis to the axle can be either year, they are the same, but some later 4th gens have 2 apparently for the 4 channel ABS
Car: 92 Camaro Z
Engine: LS 5.3 LM7
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
