Iron combination valve modification
Old May 11, 2012 | 07:08 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Some background...I have now at my -85 Camaro iron Delco-Moraine rear disc calipers and original iron combination valve.I'm going to replace rear calipers and discs to -95bpr units.If bpr brakes don't make enough brake force to rear I have to increase rear brake line pressure.
Are spring and piston at that iron combination valve under hex nut which is underside of valve?
Also does someone have idea how much do I need to increase spring pressure?
Old May 12, 2012 | 03:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Iron combination valve modification
Several choices of valves: the first-design 1LE valve, which is a bolt-in, an adjustable, such as Wilwood, or the spring modification that you are curious about. More about the latter below:
https://www.thirdgen.org/forums/brak...e-upgrade.html
JamesC
Old May 22, 2012 | 03:14 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
I changed mine in my iron PV to a 37"/lb. spring from Grainger. They come in a pack of five for about $5 Part # is 1NCF2 I believe.
Old May 22, 2012 | 07:20 AM
z 28 jari's Avatar
Engine: 385
So iron valve has same dimension spring as aluminium valve?
Old May 24, 2012 | 04:31 AM
Arvizu9618's Avatar
Apparently, it's working like a champ in mine.
I have a 1NCF2 spring for sale $2 shipped
paypal is: arvizu9618@***.net
BTW, yes, spring and valve are on the underside of the valve, I believe the hex nux is 3/4"
Old May 24, 2012 | 05:09 AM
z 28 jari's Avatar
Engine: 385
PM sent.
Hotrodboba400
Dec 10, 2019 07:07 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
