Brake light trouble
Old Jun 5, 2012 | 10:30 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Brake light trouble
Ok so i got a brake light that radomly came on today after i left the gas station. So i did some first checks to see if the light would go out. Filled the master clyinder with brake fluid, made sure the e brake was all the way down, check under the car by each tire to see if it was dripping out when pumping the pedal no fluid poured out on the ground. What could be the problem im having. 88 gta with 89 pbr rear end if this helps an stock single cast iron calipers up front stock 88 master cylinder an proportional valve.
Old Jun 6, 2012 | 11:27 AM
Engine: LR4 4.8
Re: Brake light trouble
70 views an nobody knows what could cause this i just tryed bleeding all calipers an the light is still on someone please leed me in a direction
Old Jun 6, 2012 | 11:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Manual:
"The valve and switch are so designed that the switch will latch in the "warning" position once a failure has occurred. The only way the light can be turned off is to repair the failure and apply a pedal force to develop approximately 450 psi line pressure."
JamesC
Old Jun 6, 2012 | 07:33 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
When mine was coming on and going off [ coming on randomly ] it was the master cylinder.
Old Jun 9, 2012 | 04:18 PM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Mine came on with wheel cylinders then again with the brake booster.
check the simple things first. Vacuum hose come off? That little valve the vacuum hose connects to broken /not functioning?
Proportioning valve ok?
Air in the master cylinder? Yes you can bleed the brakes and still somehow have to bleed the master cylinder.
Is the car making enough vacuum to support the brake booster?
There are so many variables.
Old Jun 9, 2012 | 06:24 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Maybe check the switch at the base of the handle?
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
