Emergency Brake Cable
Old Jun 8, 2012 | 08:27 PM
Wrench Bender's Avatar
How do you remove the emergency brake cable from the backing plate on rear drum brakes? Am very puzzled.
Old Jul 5, 2012 | 01:15 AM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Re: Emergency Brake Cable
Just did it ... when looking from where the brake shoes are there are three tabs that stick out around the outside of the e-brake fitting that goes through the backing plate. You need to compress these to pull the cable out through the back side of the backing plate.
You can usually get one or even two started through the hole by angling them through the opening. Use a screwdriver or pliers to compress the remaining one(s) and the cable will pop right through. It can definitely be frustrating even when you know what needs to be done.
Hope this helps.
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
