LS1 hub question
Old Jun 14, 2012 | 10:52 PM
TKEY's Avatar
Car: 88' Camaro
Engine: 421 stroker
Transmission: 350 Turbo
Axle/Gears: 3:73
LS1 hub question
I'm upgrading my brakes on my 88 camaro to ls1 brakes. I have everything but the hubs. Friend of mine has a pair of hubs that was upgraded for ls1 brakes, but he never installed them on his truck. Will his hubs fit on my car?
Old Jun 15, 2012 | 12:09 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: LS1 hub question
Was the truck a first gen S10?
Old Jun 15, 2012 | 05:12 PM
TKEY's Avatar
Car: 88' Camaro
Engine: 421 stroker
Axle/Gears: 3:73
Yeah!
Old Jun 15, 2012 | 11:11 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Then yes, you can use them. The 2wd first gen s10s use the same 5064 hub/rotor that non-1LE thirdgen fbodies did. So if he's already cut the rotor off, just make sure the diameter is small enough to fit inside your LS1 rotors and you'll be golden.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
