Rear Disc Upgrade ?
Old Jun 24, 2012 | 09:22 AM
M&M_GTA88's Avatar
Car: 1988 GTA
Engine: 383 Stroker L98 TPI
Transmission: 700 R4 w/ B&M Shift Kit
Axle/Gears: Stock BW LS 9 Bolt with 3.27 gears
Rear Disc Upgrade ?
Existing 1988 GTA stock rear brake system with cast iron calipers etc.
My question:
What is necessary to upgrade to the 1LE set up on a rear axle? Parts houses stock the calipers, rotors and pads for this upgrade but what about the other items I may need.
Mounting bracket?
Hard lines?
Brake hoses?
Parking Brake cables?
Of course I'll need calipers, rotors and pads but what about the above items. I'm also trying to get a grip on the cost and time factors.
Any help is much appreciated.
Thanks,
Mike
Old Jun 24, 2012 | 10:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear Disc Upgrade ?
My question:
Mounting bracket?
Hard lines?
Brake hoses?
Don't forget the combination valve.
Most of your questions will be answers below:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Jun 26, 2012 | 03:36 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
You can always find a rear disc 93-97 V8 Firebird or Camaro in the salvage yard and get the backing plates and calipers and carriers etc and swap them onto your axle. You would have to jack the rear of that car up to pull the axles to get the backing plates off. This would give you everything but the e brake cables and hard lines etc for your axle. You might be able to reuse some of your old steel brake lines.
I would reccomend new flex lines over any used ones.
Old Jun 28, 2012 | 03:42 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
I would recommend doing an adjustable prop valve if you like being able to adjust the brakes so the front and rear work perfect. The stock valves seem to leave alot to be desired.
Old Jun 28, 2012 | 04:03 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I think that the advice you've been given so far (beyond JamesC link which seems to be nothing more that putting 89+ factory brakes on) is based on people forgetting one thing.....That you have a 9-bolt not a 10-bolt. Which means simply putting on bigger brakes is not as simple as just bolting them on from another car. AFAIK, there are no bigger brake options for a 9-bolt beyond the factory 89+ disc brakes with the aluminum PBR calipers.
Old Jun 30, 2012 | 11:54 AM
87350IROC's Avatar
Car: 87' IROC
There are other options. FlynBye makes a kit to install 2010+ SS calipers on a 9 bolt. However you lose the e-brake. I have designed a bracket to incorporate the e-brake.
Old Jun 30, 2012 | 01:37 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Hey. Off topic bit are you going to the all Chevy car show on the 8th in Issaquah. I would love to check your car out.
Old Jul 3, 2012 | 01:10 AM
veltboy618's Avatar
Do you know if there is another company that makes this conversion bracket. Flynbye has shut down their cart & I called but cant get in touch with Ed.
http://www.flynbye.com/catalog/i57.html
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
gta90
Sep 15, 2015 04:00 PM
