Stupid Important Question. How do I get the Drums off of the rear, and discs on? HELP
Old Jul 29, 2012 | 05:37 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Trying to take the drums off of my rear end. Do I have to take the diff appart and pull out the axel? I figure that there must be an easier way. I'm doing this right now so a prompt response helps. THANK YOU!
Old Jul 29, 2012 | 05:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Stupid Important Question. How do I get the Drums off of the rear, and discs on?
yes you will need to remove your diff cover and c-clips to remove the axles.
Old Jul 29, 2012 | 05:57 PM
Car: 1992 Camaro RS
Dammit. Thanks.
Old Jul 29, 2012 | 06:00 PM
Engine: Lb9
Transmission: M20
Originally Posted by SKELITOR117
Dammit. Thanks.
, my name is not Dammit
Old Jul 29, 2012 | 06:32 PM
Car: 1992 Camaro RS
I'll put that down in my list of NOT names.
Old Jul 30, 2012 | 10:40 AM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
If you're lucky, you won't have to cut the big bolt that holds the backing plate to the axle flange on the drum setup. Just know it is really touch to back it out.
Old Jul 30, 2012 | 10:55 AM
Car: 1992 Camaro RS
Yah. Looks like that's what's going to have to happen. That thing is really stuck back there. I'm going to try to hammer at it later and loosen it up.
Old Jul 31, 2012 | 08:31 PM
That'd be pretty tough, as easy as popping the axles out is.
Old Jul 31, 2012 | 08:53 PM
jimmy_pop15's Avatar
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Are you saying you're doing a disc brake conversion? It sometimes depends on what brand/type of conversion you're doing. Some require axle removal some don't.
Old Jul 31, 2012 | 10:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I can't imagine how a drum to disc conversion would work without taking out the axles to change the backing plates.
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
