92 camaro center rear brake hose
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
Does anybody have a part number for the center rear brake hose? It goes from the body to the rear end housing. I cant find this thing anywhere.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 92 camaro center rear brake hose
are you asking about bendix 77397 or wagner BH110421 ?
http://www.ebay.com/itm/BENDIX-77397...0a6dc3&vxp=mtr
Car: 92 camaro
Engine: 409 sbc
Im not really sure. I took my car apart years ago. Im trying to put brakes back on it and all I have for the rear is the two hard lines that go to the drums. Im assuming there is a rubber hose line that mounts to the rear end and goes to the body. Heck Im not even sure where it mounts to the body yet. That bendix line you posted looks like maybe what I need.
Car: 92 camaro
Engine: 409 sbc
I punched in the Wagner number on Oreillys website. It came up with this.
http://www.oreillyauto.com/site/c/de...yword=bh110421
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
The rear brake line runs in the hardline bundle with the fuel lines down the drivers side of the car. When the fuel lines go up to the tank the brake line drops out and has a bracket bolting it to the body. Shouldn't be hard to follow it out and find it.
O'Reilly's will be able to look up the hose, and in my case they had it in stock. Make sure to give correct YMM of the chassis and brake lines. There were several thread pitches and fitting styles used, not just the standard pre and post-metric.
Car: 92 camaro
Engine: 409 sbc
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
The brake hose that came up for the wagner number is the center hose. Their computer says outside for non performance cars. There was no brake hose for the outside of nonperformance cars as that was drums. The picture is right though.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
