Are 4th gen Rotors the same?
Old Aug 22, 2012 | 03:06 PM
Nyczbubba's Avatar
Car: 1992 Camaro Z28
Engine: 5.7L TPI
Transmission: 5 speed
Axle/Gears: 3.47
Ok so I bought a 1992 camaro z28 with a 4th gen rear. I don't know if he swapped the brakes over or not. Well it's disc in the back. I know the brake pads are the same, so I ordered them. I need new rotors so are the 3rd and 4th the same? How can I tell if mine are 3rd or 4th gen brakes?
Old Aug 23, 2012 | 04:54 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: Are 4th gen Rotors the same?
If the calipers are smooth towards the outside instead of finned all the way from inside to outside they should be 4th gen calipers. Also 4th gen calipers have the round damper mounted to them and most third gens do not. Use the 4th gen rotors as they are able to be used with the regular 89-92 style 3rd gen rear discs. They have a slightly different size inside the hat area but otherwise they are the same in all dimensions that matter.
Old Aug 24, 2012 | 12:06 AM
Nyczbubba's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.47
Ok great, thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
cam-mike
Aug 24, 2015 07:23 AM
