Replace Standard Brakes with Performance Package Size?
Old Aug 23, 2012 | 09:09 AM
joshhsi's Avatar
Car: 1991 Camaro Z28
Engine: 305 TBI
Transmission: 700r4 w/B&M Shift Kit
I have a 91 z28 without the performance package. It has the stock 10.5 inch brake rotors. I was wondering if anyone has swapped the standard size rotors and calipers out for the performance package size 12 inch rotors and dual piston calipers? If so, what all needs to be replaced? Also, will the bigger rotors fit with a 15" wheel? (older z28 5 spoke wheels)
Old Aug 23, 2012 | 09:30 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Replace Standard Brakes with Performance Package Size?
Yes the 1LE brakes will fit within the factory 15" wheels. You'll need eithe different spindles or modify your own. There are about a million threads on this. Check out the stickeys on the Brake Board first. Good luck.
Old Aug 23, 2012 | 10:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://web.archive.org/web/200605221.../1LEbrake.html
JamesC
Old Aug 24, 2012 | 07:43 AM
joshhsi's Avatar
Engine: 305 TBI
Thanks Guys!
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
knight72
Aug 10, 2015 09:32 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
