rear end / brake question
Old Sep 17, 2012 | 09:10 PM
85silverz28's Avatar
Car: 1988 iroc z
Engine: 5.7 liter
Axle/Gears: 2.77
I was going threw a local scrap yard and found a 88 or 9 iroc with a ile or g92 rear end in it. What do u guys think its worth. And is anyone looking for one. Id hate to see it get scrapped.Id get it for my car but wanna keep it stock. I can find out more if anyone is interested.
Old Sep 17, 2012 | 10:21 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: rear end / brake question
1LE is more used to refer to the front brakes I believe since they were 2 piston design. If it's a 1LE. I'd pull the front spindles, calipers, and etc all to resell them.
G92 I believe is the Posi (Limited Slip) rearend. If it's a 9 bolt probably 100-400 depending on the shape. If it's a 10 bolt you can get them for $100 all the time around here at the yard. If it's cheap enough it's always nice to have a spare roller sitting around in case one explodes on you. I have a junk weld'd up 9 bolt in the garage still just for that reason.
The big things I look for when I'm out is 1LE front brakes, does it have a non-ac heater box, does it have the flash light overhead console, does it have aftermarket parts at all, does it have a 9 bolt, or did someone do a LS1 driveshaft swap in it. Other than that I check out the new firebirds/camaros for interior (seats, center console) and LS1 driveshafts. In any of those cases I can buy parts here cheap enough in the yard to double or triple my investment.
Old Sep 18, 2012 | 09:14 PM
Car: 1988 iroc z
Engine: 5.7 liter
Axle/Gears: 2.77
here is a pic of the rear end in the 89 . Is this just a g92 brake set up? Its definetly not a g92 or 1le car. Any one have any ideas?
Attached Thumbnails rear end / brake question-camaro-rear-end.jpg
Old Sep 19, 2012 | 06:10 AM
Engine: 383 SBC
Those are a PBR setup.
Old Sep 19, 2012 | 06:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The brakes are the typical set-up for an 89+ J65 car. In 89 the rear would be a 9-bolt, 90+ a 10-bolt. Amusingly, the above is often called the performance package or 1LE by parts stores.
JamesC
Old Sep 19, 2012 | 08:48 AM
Car: 1988 iroc z
Engine: 5.7 liter
Axle/Gears: 2.77
Assuming the gears haven't been changed its a 277 posi. Would it be worth getting?
Old Sep 19, 2012 | 09:17 AM
Engine: 383 SBC
If 10 bolt and you wanted the brakes could pull those depending on the cost. Fresh calipers from auto parts store are cheap normally.
If it's a 9 bolt it would be stronger than your 10 bolt, but still not really that desireable because of series and gear.
You choice.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
