Rear brakes, master cylinder and proportioning valve questions!
Old Oct 5, 2012 | 09:41 AM
Twessing's Avatar
Car: 92 Chevy Camaro RS
Engine: 3.1L V6
So my brother just recently bought a 91 Camaro and we replaced both axle seals and both wheel cylinders and brake shoes. Now when we try to bleed the brakes we get some fluid the first time then the second very little because of the prop valve. to get it the valve to open you have to put the pedal to the floor and the valve will open again( we know this because the brake like comes on, on the dash) and then you can get more fluid. Is this normal? Also, when pressing the pedal after it is hard, large air bubbles arise from inside the master cylinder. I dont think this is normal.
Old Oct 5, 2012 | 11:34 AM
Twessing's Avatar
Engine: 3.1L V6
Re: Rear brakes, master cylinder and proportioning valve questions!
Also, brakes seem to bleed best when engine is running, is this ok to do?
1992 Trans Am
May 10, 2023 07:19 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
