Are all master cylinders the same?
Old Oct 17, 2012 | 04:55 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Does anyone know if the master cylinders were the same for all brake options? I know that the prop valves were different but is the master on a disc/drum setup the same as one on a disc/disc setup?
Old Oct 17, 2012 | 05:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Are all master cylinders the same?
The bore varies but they're interchangeable.
Old Oct 17, 2012 | 05:45 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
I've swapped from drums to discs on the back so should I change the master for better rear brake performance or would it make no difference?
Cheers
Old Oct 17, 2012 | 06:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It'll change the pedal effort and travel, but otherwise work the same.
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
