Third gen brake rotor hub question?
Old Oct 19, 2012 | 12:32 AM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 5 speed manuel
Axle/Gears: 3.08
Just wanting to know how thick should the rotor hub be when you have them turned for the ls1 front brake swap, I know the diameter needs to be 5.87" or somewhere in that range but not sure how much meat should be on the outer width of the hub. If anyone could give me a answer I would appreciate it.
Old Oct 19, 2012 | 06:17 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Re: Third gen brake rotor hub question?
I imagine with. 030 clearance all around you should be ok. Doesnt hurt to to check, but the hub is iron...rotor aluminum. This means the rotor shouldnt pinch the hub when it gets hot. Get out the dial calipers!
Im using S10 hubs on mine. Tone rings for ABS.
Old Oct 22, 2012 | 12:59 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
What I'm wanting to know is should the the hub sit equally in the ls1 rotor lip? How much should the width of the hub be or does it even matter?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
