More 1LE frustration (bearings)
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
I'm having difficulty with the bearings. I tapped in the outer race, packed the bearing, placed it in the race. For the love of all that is holy, the seal will NOT seat. In fact, when everything is in place, it doesn't even look like it will fit. I did check for fit before I installed the race and it looked fine, but now it just won't fly. What am I doing wrong?
Re: More 1LE frustration (bearings)
that bearing race is nowhere near seated, it has to go in all thw way to the stepped bore where it bottoms out. USE A PRESS!! You can see the pressures climbing w/ a press, that's when you stop.
This is how deep it goes in there:
Axle/Gears: '01 3.42 10 bolt
in the last of the three pics you posted, it doesn't look like the old race was removed. if you purchased these rotors new, they usually come with the bearing races already in place
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
X2! Just get a punch and tap the one you put in out of the hub and put the bearing in the already seated race, you should be good to go then.
Engine: 355 TPI
Yeah, I waited until morning and checked. I just pressed in the bearing on top of the supplied one. I felt pretty stupid. At any rate, I took it out and everything went together smoothly.
