10 bolt Question
Old Nov 7, 2012 | 08:09 PM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
10 bolt Question
Guys, need some help with my rear end swap. Currently, my 9 bolt in my 89 iroc needs to be refurbed because it has 150k miles on it and it only does a one wheel peel. I was going to pull the cover and inspect it this Christmas but instead just got a built TG 10 bolt from another local TGO. So with my fiances tight I need to use the 9 bolt PBRs with the 11.6" rotors on this 10 bolt. I did find that Ed Miller sells brackets that work Item #DiscConvBkt
http://www.flynbye.com/catalog/i29.html
My question is why would someone use this other bracket with 12" rotors?
Item #DiscConvBkt12
http://www.flynbye.com/catalog/i162.html
Old Nov 11, 2012 | 11:14 PM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 5 speed manuel
Axle/Gears: 3.08
Re: 10 bolt Question
Just to have bigger rotors
Old Nov 12, 2012 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The only difference between the 9- and 10-bolt rear disc system is the backing plates. That said, the following should shed some light on the conversion:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
