98 ls1 rear e brakes
Old Nov 28, 2012 | 07:06 PM
L98wit's Avatar
Car: 91 rs
Engine: 350 tbi with EBL
Transmission: t56!
Axle/Gears: 2.733
So I recently swaped an ls1 rear end and I also bought e brake cables from flynbye so I installed it an I turn on the car and the e brake light is on and I put the car in gear an the e brakes were infact engaged even though the lever is down. I notice that wen I lift the handle it moves maybe a half inch up. Any tips on how to let my e brakes disengage?
Old Nov 28, 2012 | 08:19 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Re: 98 ls1 rear e brakes
As you siad it is engaged...back off the adjusters........
Old Nov 28, 2012 | 09:13 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That alone shouldn't cause the light to come on. I'd also check the switch that the handle depresses - it engages when the handle is lifted to turn on the dash brake light.
To get movement in the handle, back off the adjusters in the park brake drums as Jetmeck noted.
Old Nov 29, 2012 | 10:43 PM
L98wit's Avatar
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
i found the adjusters and its better now. the light is still on(my brakes are still spongy after bleeding) so im assuming my master cylinder is on its way out (looks dirty on the inside) hopefully changing the master will turn of the light.
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
cam-mike
Aug 24, 2015 07:23 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
