Black brake fluid after flush
Old Apr 26, 2010 | 01:30 PM
joshwilson3's Avatar
The brake fluid in the reservoir of my 89 Firebird tends to always be black. I had it flushed a year ago, and I noticed it got black. I had it flushed last week and two days of driving. I checked the fluid and it was black in the reservoir.
What is causing the brake fluid to turn black so fast?
Old Apr 26, 2010 | 01:33 PM
Dmity Kiev's Avatar
Car: Firebird 91
Engine: Vortec 350 224/230cam, ported head
Transmission: TH700r4 with vette servo,hd oil pum
Axle/Gears: now 3.73 posi old 3.23 posi
Re: Black brake fluid after flush
time to change brake lines
Old Apr 26, 2010 | 02:04 PM
So, bad brake hoses cause the fluid to turn black in the reservoir?
Old Apr 26, 2010 | 08:34 PM
What rubber brake hoses are good? Autozone has Brakeware. And Advance has Tru Torque and mentions "Dorman - First Stop".
And I think Napa has their own brand for rubber hoses "Napa Ultra Premium Brake Parts".
Actually I just looked, and it looks like Napa is a limited lifetime. Where as Advance is one year. And Autozone doesn't say, but I'm guessing since it doesn't say then it probably is 90 days.
So for this, I'd probably go Napa just because of the warranty.
Old Apr 26, 2010 | 08:48 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
if you are going to do it, go with braided stainless steel since you are going to be down there anyway.
Old Apr 26, 2010 | 08:53 PM
Nope, don't want to spend the extra money. And I've read of the stainless steel hoses braking on people.
They said those stainless steel brake hoses will brake. Where as the rubber will just get worse and worse, but still let you stop.
This is just a DD. No point in getting fancy like some recommend putting in Amsoil fluids or fancy spark plugs. I'm just keeping it OEM as it tends to be a no brainer.
Old Nov 8, 2012 | 11:29 AM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
Amsoil will last longer between flushes.
Old Nov 8, 2012 | 12:15 PM
gp90gta's Avatar
Car: 1990 GTA
Bad seals in a master cylinder will also cause the fluid to turn black.
Old Nov 8, 2012 | 02:07 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Had the same thing.
I suspect it was the master cylinder seals, so I bought a complete new master cylinder from Amazon for $50 (from memory). It's so cheap I'd do it to be safe.
I also put in a set of Goodridge stainless steel brake lines. These were great and a good upgrade.
Old Nov 29, 2012 | 09:29 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Stainless steel braided brake hoses are far safer and superior to plain old rubber. whoever stated that SS hoses are a bad idea is very unacknowledged about the subject. I have had mine for at least five years with zero problems. They provide better braking by eliminating the expansion of rubber hoses and also have a much greater abrasion resistance, which has saved my but before.
Old Nov 29, 2012 | 09:34 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Brake fluid has a life span and should be changed close to 25,000 miles or 3 years. The fluid brakes down and absorbs water/moisture in the air. All of the rubber parts of the brake system also disintegrate. If you don't know when the last time the master cylinder, brake fluid or brake hoses were, I would plan on changing it all. I polished a fourth gen master cylinder for my car, it seeped out blackish green fluid for for days. Every time I thought I had cleared it all, a few more drops would appear.
Old Nov 30, 2012 | 09:49 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
You should read this article. I don't think a difference of tenths of a millimeter in expansion will affect performance or pedal feel in any way.
http://autospeed.com/cms/title_Braid...9/article.html
Old Nov 30, 2012 | 10:40 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Yeah, that article doesn't help your argument. Think about it in terms of volume as that article started to hit on. If we assume the inside diameter of the brake hose expands at the same rate as the outside diameter than for our formula we can plug in the od numbers in place of the id numbers. We know volume of a cylinder is equal pi times the radius squared times the height. We can assume the brake hose length is 6 inches or converted to mm is 152.4 10.76 initial is a radius of 5.38 and 11.02 is 5.51. The difference in the cylinders is 678 cubic mm. So what could have been the caliper piston expanding outward and extra amount is now eaten by your brake hoses.
Old Nov 30, 2012 | 11:04 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Thanks for doing the math. You used the worst case hose from the article (an old worn out hose from a 1965 mustang and used the OD dimensions which would would yield an even greater final volume number) and still came up with only .68cc's difference. There is more variation than that between the under and over fill lines on the reservoir.
Old Nov 30, 2012 | 02:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The level in the reservoir is irrelevant to the hydraulic system.
The point of non-expanding hose is that more of the effort applied to the pedal is used to put force on the piston instead of being wasted in ballooning the hose. The difference in pedal feel can be quite significant.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
z28_AJ
Aug 27, 2015 08:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
