Brake Caliper/Rotor/Pad replacement questions
Old Jan 11, 2013 | 09:43 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
I am currently replacing the original OEM brake parts.
I do not intend to auto-x or race.. Its driven about 6-9 months out of the year and logs about 4000 miles tops per year in day/night VFR (good weather)
The driving I do is aggressive driving on country roads so I do want something better than OEM stock without having to upgrade the whole system.
Questions-
1)Which brand/type of OEM replacements do you recommend for front/rear disc brakes?
2) Do brake rotors normally include wheel bearings when purchased new?
Old Jan 12, 2013 | 08:21 AM
Chuck84TA's Avatar
Re: Brake Caliper/Rotor/Pad replacement questions
Old Jan 12, 2013 | 08:25 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
try some metallic pads. i believe OEM is semi-metalic.
i think wheel bearings come seperate.
Old Jan 12, 2013 | 03:00 PM
87350IROC's Avatar
Car: 87' IROC
Questions-
There are no good replacement rotors for OEM that will help with temperature control. If you insist on keeping an OEM style setup, I would look at:
brake ducting
high temp fluid
high temp pads
Don't bother replacing the rotors unless there is something wrong with them.
New rotor do not come with bearings.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Leggman1
Aug 6, 2015 04:15 AM
