4th gen to 3rd gen rear swap
Old Jan 13, 2013 | 02:01 AM
82crossfire305's Avatar
Car: 1982 Trans Am
Engine: LU5 CFI
Transmission: TH-200C
iam swapping the rear to a 94 camaro to my 82 trans am, everything will fit even the brakes, ijust need toget them to work... how and what can i switch over, and do i delete the proportioning vaulve? or do ijust swap MC? what about the booster can that swap over?
Old Jan 13, 2013 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 4th gen to 3rd gen rear swap
Many of your questions will be answered in the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jan 13, 2013 | 09:43 AM
Car: 1982 Trans Am
Engine: LU5 CFI
thank you was looking in the brakes section
Old Jan 13, 2013 | 09:53 AM
Car: 1982 Trans Am
Engine: LU5 CFI
i was reading the MC section in the FAQand it didnt answer myquestion at al i get one paragraph then nothing. also is the alink to swap ABS?
Old Jan 13, 2013 | 12:27 PM
87350IROC's Avatar
Car: 87' IROC
They will "work" as soon as you plug in the hydraulic brake line and bleed. Since you have now changed your brake efficiencies, I would look at something like an adjustable prop valve to allow you to dial in the bias. I would keep the OEM master cylinder.
Working ABS is a major can of worms seeing as how our cars don't have the controllers or wheel speed sensors.
Old Jan 14, 2013 | 12:42 AM
Car: 1982 Trans Am
Engine: LU5 CFI
so use the master cylinder off the camaro and where can i get a controlable prop. valve. also the E-brake cable is it possible to switch over the brakets that hold the lines in place with a bit of fab work? and the ABS so its not a total lost cause? i can use the rear WSS and once i get a new front end for the car i can prob modify ones the the front wheels and tie the ABS Comp into the DLC connector? cuz that would totaly elliminate my prop. valve delema.
Old Jan 14, 2013 | 10:46 AM
87350IROC's Avatar
Car: 87' IROC
Wilwood and a few others make adjustable prop valves.
I am not sure about the e-brake cable. I expect you will need a conversion cable.
ABS will not eliminate your prop valve issue. You do not want ABS engaging before it has to. The brakes still have to be balanced. ABS is not impossible, nothing is, but IMO its a ton of work and you are breaking new ground.
Old Jan 14, 2013 | 12:49 PM
Car: 1982 Trans Am
Engine: LU5 CFI
ok thanks, guess i have a lot of research to do on the ABS then before i start taking anything apart.
Old Jan 14, 2013 | 04:33 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
I did the same swap . as for the e-brake set up, I took the bracket from the 4th gen by drilling the spot welds out and welding it under my 1990 , this way i could use the cables that came with the 4 th gen . the front cable however isn't long enough. so I had one custom made for the length I needed . so after you mt the tunnel e break bracket with stock 4th gen rear cables measure the diference in length , and work it out by having a custom one or try to splice a cable , this I dont recomend as I did that and it failed after a week.
Old Apr 2, 2013 | 11:22 AM
powerdreams's Avatar
Car: 1987 camaro
Engine: 5.7 vortec
how much would one say is a reasonable price to pay for everything to do a 4th gen rear end and brake set up?
Old Apr 2, 2013 | 11:56 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
If you want new I would wait until advance auto is having an online sale. Often you can get 30-40% off. Order online and pick up in the store.
Old Apr 2, 2013 | 05:51 PM
Car: 1987 camaro
Engine: 5.7 vortec
I don't have a advance here in Ontario. And I was hoping to buy a used rear end and just new pads calipers and rotors.
Old Apr 11, 2013 | 12:24 PM
skip91's Avatar
Car: '91 RS, '64 C10 Stepside
Engine: 305 TBI, '00 5.3
Transmission: Manual, Automatic
Axle/Gears: 4th Gen with 3.42, 4.10
I picked up the 4th Gen torque arm along with the rear end. Do I need to use that for the swap? Is the 4th Gen better than the 3rd Gen? He also gave me the 4th Gen shocks. Any benefit to using those? I don't want mine to ride any higher or lower, she's perfect right where she is. I recently installed a set of Vette C6 wheels and love the height.
Old Apr 11, 2013 | 09:39 PM
Car: 1987 camaro
Engine: 5.7 vortec
Thread jacked!
I don't really know from experience yet, but I have heard and read mixed opinions on the 4th gen rear end being better and stronger over our stockers. To me, it only makes sense that it would be stronger and as a result better. Im sure u could use used shocks but why? Buy new ones. As far as i know u dont need the torque arm to do the swap. Keeping in mind though, 4th gen rears overall length is slightly more than what u are using now.
Nice car btw
Old Apr 12, 2013 | 06:40 AM
JamesC's Avatar
Same 28-spline axles as the 89-92 cars. No stronger.
JamesC
Old Apr 22, 2013 | 11:15 AM
skip91's Avatar
First off, if I have "thread jacked", I apologize. Not really sure what thread jacking is. I just figured that since there is already a thread concerning someone else doing the swap, I would join in.
Got my rear end swapped, but had some issues.
1. My C6 Vette wheels do not fit. The center of my wheels do not fit over the center of the axle. I had to put my 2" adapter back on and it looks like crap. About 1-2" of rubber sticks out past the fender. Also, pretty sure that when I do figure out how to get them to fit, they will rub the fender well pretty bad in some spots.
2. The drivers side brake bleeder valve is rounded so I couldn't bleed that side, but did do the passenger side with no issues.
3. Already knew this, but gonna have to get a custom set of parking brake cables made.
4. I have no idea where to put the adjustable proportioning valve I bought. Do I keep the stock proportioning valve and add it inline with the the rear brake line or remove the stock proportioning valve altogether.
1992rs/ss
16
Jan 28, 2016 09:58 PM
sailtexas186548
Jan 19, 2016 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
