84 TA rear disk handbrake again.
Old Jan 26, 2013 | 04:53 PM
Cosmik Debris's Avatar
Hi Guys, i have the usual problem with the handbrake. The rear calipers have been rebuilt and are working correctly, the problem is, in New Zealand where I live, we have 6 monthly vehicle checks and they are very hot on hand brakes. In NZ they are supposed to be emergency brakes rather than a parking brake.
Summit only seem to list a Cardone re-manufactured caliper with a handbrake for my car. Has anyone used these, are they any good?
My other option is to substitute a better caliper from a different car/model. What calipers with handbrake will fit without modification (they frown on that as well)? I have 18" rims.
Thanks for any help on this, living here doesn't give me a lot of options, i.e. there aren't a lot of wrecked cars to get parts off.
Old Jan 26, 2013 | 07:09 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: 84 TA rear disk handbrake again.
Have you considered the rear disc setup from the 98-02 4th gens? They have an integral drum parking brake in the rotor hat. Assuming you have a 10 bolt rear, these will bolt right up. I did this to my 89 (I had a disc setup from an 83 Trans Am). My park brake is 4th gen from the handle all the way to the wheels.
I have some pics of the swap here on Cascade Crew forums
http://www.cascadecrew.org/phpBB2/vi...light=ls1+rear
Old Jan 26, 2013 | 08:27 PM
I have now. That will work but getting the parts will not be easy, what I really need is just a straight caliper swap. There aren't many wrecked 4th gens around here.
Cheers
Old Jan 27, 2013 | 01:31 PM
Al Hasse's Avatar
FWIW, I had the work of pulling them done for me and bought the whole kit from e-Bay. It came with the lines and rear cables, then I pulled the forward cable, bracket and handle and handle from a 4th gen bird.
Also worth a look, though I don't know how is international shipping goes, http://flynbye.com
http://flynbye.com/catalog/i60.html
Mine were used and still quite dirty when I got them, Ed Miller's will be clean and new. Mine were quite a bit less, but more work to install.
Old Jan 27, 2013 | 02:32 PM
OK thanks, definitely worth looking in to.
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Bob88GTA
Aug 24, 2015 08:57 AM
86IROC112
Aug 21, 2015 07:20 PM
Winchester1094
Aug 18, 2015 10:23 AM
