Question about gen 1 CTSv brakes with Z51 rotor
Old Feb 17, 2013 | 03:42 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I had some brackets made up for the conversion per Pocket's thread from a year ago (thank you for posting your bracket design). Everything lines up nicely except I need to have about 1/2" worth of spacers due to one of the bracket-to-strut bolts interfering with the caliper.
ebmiller's thread from a few years back references needing a spacer for this swap, too.
Is that too much space and thus mess up my caliper to rotor alignment? That is what I am most worried about.
Thank you
Chuck
Attached Thumbnails Question about gen 1 CTSv brakes with Z51 rotor-wp_20130217_007.jpg
Old Feb 17, 2013 | 05:34 PM
87350IROC's Avatar
Car: 87' IROC
Re: Question about gen 1 CTSv brakes with Z51 rotor
Chuck,
Unfortunately, this swap is a non-starter. The CTS-V pad height is taller than the annulus of the rotor. This is true of any of the C5/C6 rotors. The pad will overhang the rotor by ~3/8" IIRC. What do you plan to do about that?
I can't believe people keep thinking this is going to fit. Maybe we need a sticky on this at some point. I have seen many people waste a ton of money just to realize this later.
Overlooking that issue...
How thick is that bracket? It looks thin. Maybe to thin?
Finally, yes the bolt head is an issue. I have decided to reverse the direction of the lower bracket to spindle bolt, then drill out the spindle, machine a flat for the bolt head and tap the bracket. If the bracket was designed to be a certain thickness, then all the sudden you add 1/2", then yes, that is going to blow your alignment.
Which hubs are you planning to use? OEM offset or 1LE?
John
Old Feb 18, 2013 | 04:26 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
John, thanks for the reply.
Luckily I only have about $2 in hardware on this thing and already had the calipers, so if it doesnt work out I didnt spend a ton of money. Had a friend make me the brackets.
There were two threads where folks said they got it to work, Dewey316 (post 258) & Stevo (post 250) a few years back with ebmiller parts (post 207 and 239 for pics):
https://www.thirdgen.org/forums/brak...er-swap-6.html
Unfortunately it looks like Dewey's pictures are no longer working and I didnt save them.
Then Pocket more recently:
https://www.thirdgen.org/forums/brak...pers-17-a.html
ebmillers looks like he uses a significantly smaller bolt head and about 1/4" spacers. Pocket said the pad surface fits the rotor fine, but I thought I read what you did about having a bit of overhang.
Bracket was supposed to be 3/8", but I didnt mic it yet so you may be right. Was planning on using OEM offset.
Old Feb 18, 2013 | 06:00 PM
87350IROC's Avatar
Car: 87' IROC
Yes I am aware of those threads. But I have personally tried this combination, it doesn't work. I guess you could "not notice" the overhang, and continue on with life, but that is not my idea of a job well done.
Maybe I need to get on those threads.
Well I can tell you that if you use the Camaro SS rotor, you will need to use the 1LE offset to get a thick enough bracket.
John
Old Feb 19, 2013 | 07:16 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Thanks for all the info. I have a note out to hawks to see if there's anything else out there that fits the caliper off say a EVO or STI that's just a bit smaller. If I cant do that then I'll take your suggestion and punt and find some 18s to run with a standard bracket.
Chuck
Old Feb 19, 2013 | 10:39 AM
87350IROC's Avatar
Car: 87' IROC
Chuck
Your a talking about an alternative rotor?
EVO / STI may work but they use smaller calipers.
C4HD rotor might work, would need to measure. Either way you would likely need to run the 1LE offset.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
redmaroz
Aug 16, 2015 11:40 PM
