Upgrading brakes using 15" prostars
Old Feb 17, 2013 | 10:39 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have 15"x7" prostars on the front.
I would like to upgrade my brakes to give me more stopping power and, most of all, weigh less than the stock brakes.
From searching, my options are the 1LE and the C4 kits.
Being I have a 1991, how much weight would I expect to lose with the 1LE or the C4 kit?
Or would I be better to just buy a vented rotors and new calipers?
Old Feb 18, 2013 | 12:37 AM
87350IROC's Avatar
Car: 87' IROC
Re: Upgrading brakes using 15" prostars
I highly doubt either will be lighter than OEM. Certainly both will have higher rotational inertia.
Also, both will actually have less torque than OEM.
Is this for drag only?
Also, OEM rotors are vented, so no need to replace rotors for that.
John
Old Feb 18, 2013 | 08:57 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
It is for street/strip.
So is there a caliper or rotor to fit the OEM that is much lighter?
Old Feb 18, 2013 | 11:09 AM
87350IROC's Avatar
Car: 87' IROC
Something like this would likely be lighter.
http://www.wilwood.com/BrakeKits/Bra...sc+Brake+Rear.
They have the same torque as stock, but are aluminum.
Since you would like to retain street duty, I would not recommend any of the drag kits.
Something like this would also likely be a good bit lighter than OEM.
However I am not a big fan of those calipers on the front of our cars.
John
Old Feb 19, 2013 | 04:25 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Would this
http://www.summitracing.com/parts/su...t/model/camaro
or this
http://www.summitracing.com/parts/ss...r/media/images
be the same as the wilwoods?
Summit says their caliper is 8.1lbs, so what would a stock caliper weigh?
Old Feb 19, 2013 | 05:02 PM
profootbrake2's Avatar
Car: 92 Camaro Z28
Engine: ZZ4 TPI
Wilwood makes a bolt on single piston caliper like that. But if you want to loose some weight i would upgrade to a street/strip set up like these from aerospace components. I have used there drag racing brakes on my car. Wilwood also make brake packages for these cars
http://shop.aerospacecomponents.com/...-92camaro.aspx
Old Feb 19, 2013 | 06:24 PM
87350IROC's Avatar
Car: 87' IROC
Would this
or this
At 8.1lbs I doubt they are lighter than stock. Seriously though, I expect those to weigh less than 8lbs.
Either way, those calipers product less torque and a shorter pedal than stock. Is that what you want?
Old Feb 19, 2013 | 06:28 PM
87350IROC's Avatar
Car: 87' IROC
Yup, I linked to it above.
I wouldn't bother with that kit. Sure they may statically be lighter than OEM, but they will have a lot more inertia due to the larger diameter. Ever watch a professional ice skater?
Billy Decker
Sep 4, 2015 03:46 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
