larger rotors, help
Old Feb 19, 2013 | 09:17 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
larger rotors, help
my rotors on my rs are beat to hell, i beat on them fairly hard and tend to warp them allot lol. sooo im in need of new rotors , sense i need new ones and im on a tight budget, i was thinking of the possibility of using stock calipers with larger rotors. does anyone know of a bracket to do this? please
Old Feb 19, 2013 | 09:27 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Re: larger rotors, help
i guessing i need to make new hubs and do a two piece rotor and hat ? im eventually going to do zl1 calipers anyway so i figure one piece at a time sense i need to do it on a budget
Old Feb 19, 2013 | 09:29 PM
morrow's Avatar
Car: 92 Camaro Rs.R
and..... can i just use 4th gen hubs?
sense they are 5 on 4.75
Old Feb 19, 2013 | 10:40 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
no, you can't.
look up the hubs on NAPA or rockauto and you will see why.
Old Feb 19, 2013 | 10:43 PM
morrow's Avatar
Car: 92 Camaro Rs.R
i know the spindle is different, but i dont see the difference of a cut up stock disc to creat the hub or the 4th gen hub... are the bearings the same size and the shaft the same size?
Old Feb 19, 2013 | 10:47 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Go to lukeskaff.com and you'll see a pretty complete list of the more easily done options, what you need to do and what parts you'll need.
Old Feb 19, 2013 | 11:06 PM
morrow's Avatar
Car: 92 Camaro Rs.R
ok, thanks.
Old Feb 20, 2013 | 10:34 AM
87350IROC's Avatar
Car: 87' IROC
No, they used a sealed bearing like all modern cars. They don't have a spindle shaft per say, and the bearings aren't serviceable.
You will have a HECK of a time uprgrading to ZL1 calipers one piece at a time. The rotor thicknesses are all off.
Old Feb 20, 2013 | 06:14 PM
novaderrik's Avatar
Car: 86 Camaro
if it was as easy as just popping a later model hub onto the stock spindle, then these late model brake swaps would be a hell of a lot simpler.. hell, even GM had to modify the existing spindle to run a larger rotor in the 90-92 cars with the bigger 1LE brakes, and the modifications they made back then are almost exactly the same ones that people do to put bigger brakes on to this day..
like i said, look at pics of the rotor/hub for a 3rd gen and a hub for a 4th gen and it starts to make sense.. better yet, maybe head to a junkyard and see if they'll let you look at different cars to help better visualize how it all goes together- that will tell you a lot more than the typed words from random strangers on the internet..
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
dbrochard
Sep 19, 2015 08:13 PM
