Anyone use the hassle free disc brake conversion?
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
Has anyone used this? http://www.flynbye.com/catalog/i30.html If so what are your thought and did you have any problems? thanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Anyone use the hassle free disc brake conversion?
the problem would be to get them to ever ship the patrs
Car: 84 firebird
Engine: 355
Car: 1986 Firebird
Engine: 6.0L LSX
Got my stuff today as a matter of fact, granted it took a bit from time of order but I'm not in a rush so I didn't really care. I'm sure the guy doesn't keep a huge inventory and makes stuff as ordered to keep costs down and parts affordable.
Car: 84 firebird
Engine: 355
i live in ontario canada so im gonna assume it will take quiet a bit of time to get it...i have a full disc brake rear with a rough housing just thinking this might be an easier route to go instead of cutting and drilling holes
Engine: Lb9
Transmission: M20
I ended up getting andyz28.com spacers and shims and nos brackets for my conversion because ed was took months and would not reply to any emails.
Car: 84 firebird
Engine: 355
Engine: Lb9
Transmission: M20
http://andyz28.com/3rdGen/reardisc.html
if you have a 10 bolt you will need to shim the mounting plates. If you email them they will sell parts seperatly. Drum axle housing is smaller so you need the centering shim to take up the spoace and stress off the bolts and it centers the mounting plate. You might even post in the wanted section for used caliper mounting plates.
Car: 84 firebird
Engine: 355
Engine: Lb9
Transmission: M20
my swap was a little different and im verry pleased. I did the swap on my 67 camaro.I used new 10-12 bolt pbr backing plates spacer and shims from andyz28.com. I used a adjustable proporting valve from ssbc and called up baer brakes and used flex lines and ebrake cables from there pbr kit for first gen camaro's. I rebuilt some pbs's I got from ebay and purchased new rotors and pads. For my conversion I had to have the axle flanges machined down.
Car: 84 firebird
Engine: 355
Engine: Lb9
Transmission: M20
JamesC did a nice wright up on the aluminum pbr caliper swap. But alot of the part number he provided are nla.
Car: 84 firebird
Engine: 355
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Gives a professional and clean job, like it came from the factory.
Off cours some parts can be purchased separately from different places too.
Here the pics of my conversion https://www.thirdgen.org/forums/brak...m-o-e-j65.html
Where did you find NOS brackets? I have been looking for a pair for over 2 years with no luck.
Engine: Lb9
Transmission: M20
I purchased them along time ago before they were discontinued in 05. I didnt take many pictures here is a mockup before I located the nos mounting brackets. very nice instal there thomas1976 worth the trouble.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
